Tight fit on crank bearing.
Old 08-08-2006, 09:40 PM
Dr. Teeth's Avatar
Default Tight fit on crank bearing.
I just installed a new Centerforce clutch on my 96 and when I reinstalled the trans the last 1/2 inch or so was a rather tight fit. I figured I may have dinged the bronze bearing when I pulled the trans in the first place,but thenI read anotherpostand aparently it's ok to pull the last 1/2 inch or sotogeher with the olts evenly?
Before I put it all back together, is this going to be OK?
Old 08-09-2006, 09:29 AM
NVR_SPDS's Avatar
Some of the resistance your getting, is the slave cylinder compressing slightly. I have installed my trans, but pulling the last little bit with the bolts.. Ill put in 4 bolts, basically one on each corner, and try to tigten them as even as possibly, and havent had any problems with the trans, or clutch.
Old 08-09-2006, 09:56 AM
Dr. Teeth's Avatar
Well, since mine's an LT1, the slave sylinder is not on the trans input shaft. I have a clutch fork, and the slave sylinder was unbolted from the car. I am starting to think that maybe I buggered up the pilot bearing.
Tonight I am going to get back under there and have my wife hold the clutch pedal down, while I am turning the ouput shaft with the car in gear, engine off. I surmise that if it turns freely then the disk was maligned slightly and I am fine. If not, I'm up ****'s creeek and need a new pilot bushing....
Any thoughts on that?
