T-56 Measurement Request
I've been searching for quite a while both here and on the net and I can't seem to find these measurements on an LS1 T-56.
I need the distance from the end of the bell housing (engine side) to the tip of the input shaft, whether it be positive into the bell housing or negative sticking out of the bell housing.
I also need the distance from the end of the bell housing (engine side) to the face of the throwout bearing.
The easiest way to get these I would assume is to lay something flat against the mounting flange and then measure down to the input shaft and throwout bearing. Accuracy within a 1/16" (tape measure quality) would be fine for what I'm wanting to do. If some one could also get these measurements off of an old school Gen 1 SB trans that would be cool, but I can probably find one local.
Thanks
Thanks
http://www.t56rebuilds.com/
Info / HelpLine
Telephone:
(888) 937-4411 ( Toll Free Direct )
(713) 937-4411 ( Office Direct )
(832) 488-0533 ( Cellular Direct )
(713) 937-4420 (Fax Direct)
Facsimile: (713) 937-4420
Email:joe@t56rebuilds.com
Info / HelpLine
Telephone:
