Strongest T56
Old 08-09-2006, 07:12 PM
Ari G's Avatar
Default Strongest T56
I´m looking for a T56 for a LS6 Engine the Can handle 1000-1200rwhp
Any recommendation to Builers and What clutch?
I have A DF Centerforce in my Camaro that is like a dream in a Can.
Will a Df clutch handle 1000rwhp or shoul i go with Mcleod twin?
Old 08-09-2006, 07:56 PM
NVR_SPDS's Avatar
Dont think the DF will handle that kind of power, but i know Rockland Standard Gear has a T56 rated at 1000+hp.
Old 08-10-2006, 08:34 AM
wicked_95z's Avatar
There is no way the DF will hold a 1,000hp. Def go with street twin and Rocklands "Transzilla"
Old 08-11-2006, 11:04 AM
NoMoreLS1's Avatar
Thumbs up
1200 rwhp? Why do you need that much power?
Go with a McLeod twin disk and have Finish Line Transmission build you an Extreme Duty T-56. Call Doug Ludwig or Chuck Johnson at 630-350-7776 for more information.
FLT
Viper 30 spline main shaft (machined to stock length)
Machined tail shaft housing for Viper yoke
30 spline 1350 series yoke
New synchro assemblies
Carbon lined blocker rings
Steel 3-4 shift fork
Solid keys 1-2 synchro
Solid keys 3-4 synchro
Front & rear seals
Bronze fork pads
Set end play to performance specs
Old 08-11-2006, 11:54 AM
ls1 joe's Avatar
1200rwhp you will need more than an extreme duty. The viper conversions are only rated to 750rwhp. I would vote for the tranzilla if you are in a hurry. If not a custom liberty unit is what we are building.
Old 08-11-2006, 08:49 PM
Mr. Axe's Avatar
What is the price for a custom liberty unit?
How much hp and tq can it handle?
Thanks,
Michael
Old 08-12-2006, 03:28 AM
gametech's Avatar
As long as you have a CF DF clutch, there is no way to transmit enough power through your t56 to damage it.
Quick Reply: Strongest T56
