clutch bleed
Old 08-11-2006, 04:32 PM
Canuck's Avatar
Default clutch bleed
What size socket for bleeder bolt? Thanks
Old 08-11-2006, 06:38 PM
00silver6's Avatar
took from the sticky above^
"To bleed the system, you will need a 7/16th” socket, thin-walled, in ¼ drive. It would behoove you to use a few swivels and extensions. I also highly recommend taping the socket to the extension/swivel/etc. If for some reason you drop the socket, it will end up at the bottom of the bellhousing and you will have a hell of a time fishing it out".
