Bell housing still ok to use?
I have the stock bell housing. It has 2 or 3 holes in it from something coming loose and flinging around in there. And there are a lot of scratches inside the bell housing. The holes are ~1'' in diameter but I'm wondering if it is still safe to use? I'm worrying the holes will try to connect making a crack or something?? Does that make sense... Thanks for any help.
Ive got TWO holes. One on the bottom from when I bottomed out, and the piece of bellhousing went inside, then months later it blew out the side of the bellhousing, lol. These things are WEAK, I cant believe they allow them to build them this weak. My leg would be a gonner if the clutch ever exploded.
