clutch for 600rwhp
Old 08-15-2006, 04:24 PM
hourang's Avatar
Default clutch for 600rwhp
my spec 3 is slipping with 370rwhp, and really bad when i hit the nitrous(only 75shot right now mind you). it only has like 5k miles and a few track passes on street tires 2.3 60fts. whats the most inexpensive clutch that can reliably handle the power? textrilia? can i reuse my spec billet flywheel and just have it surfaced?
Old 08-15-2006, 04:41 PM
LostCauseZ06's Avatar
is it just a stage 3 or is it a stage 3+?? if its not a 3+ then i would suggest one of them, mine is holding awesome, the textralia is also a good clutch but a bit more expensive
Old 08-15-2006, 07:29 PM
sprydncamd ta's Avatar
i wouldnt ever buy another clutch other then a textralia drive a car with one and youll see what i mean
Old 08-16-2006, 02:31 PM
hourang's Avatar
yeah its a stage 3f clutch... ls6 slave, spec billet flywheel... so yeah dont really know why its slipping.
Old 08-16-2006, 02:36 PM
tha joker's Avatar
ram clutches are cheap and it seems to be holding fine for me at almost 500rwhp
Old 08-16-2006, 03:02 PM
hourang's Avatar
anyone know this?
Old 08-16-2006, 03:21 PM
Goat Herder's Avatar
RPS 2900 lb version.
Old 08-16-2006, 05:11 PM
silver02ws6's Avatar
textrallia clutch is awsome man. Grabs like theres no tommarow and is as smooth as the stock clutch. The pedal may even be a little lighter than the stock clutch once its broke in good.
Old 08-17-2006, 10:02 AM
99Ws6TransAm's Avatar
Jeff..look into a RAM Powergrip HD. I just purchased and installed on in my 99 bolt on nitrous motor. Its supposly rated to 680hp. Good pedal, good release, im in the process of just putting some miles on it.
Old 08-18-2006, 12:26 PM
DD966's Avatar
Who did you buy yours from?
Old 08-18-2006, 05:12 PM
68ss_00ss_87_95's Avatar
i used the spec5 but it seems to hame some slipping now at 10k miles and over a dozen track passes.....not a bad clutch, im probably gonna buy another 1
