View Poll Results: Did you have your flywheel and pressure plate balanced?
Yes!
22
20.95%
uh no
46
43.81%
I just want to click on something without messing up the poll.
37
35.24%
Voters: 105. You may not vote on this poll
M6: Did you balance your FW+PP?
Old 08-19-2006, 11:27 AM
kenkaru's Avatar
Default M6: Did you balance your FW+PP?
I have never done it and it seems like most people don't. Is it really only important when reving really high like 7k+ ???
Old 08-19-2006, 11:54 AM
SS4Matt's Avatar
well usually when i buy a whole new clutch and flywheel assembly i just throw it in....but my last clutch *caugh*spec3POS*caugh*
not only did the flywheel come machined incorrectly (it was cut on an angle, only half the disc made contact with it!) but it was also not balanced at all....i had my spec3 in and out of my car a few times, one of which times was to get it balanced! it wasn't even close to balanced, just cruise'n around made my dashboard feel like it was going to rattle off!!
Old 08-20-2006, 07:36 PM
bigdsz's Avatar
It is foolish not to get the flywheel and PP balanced. For $50, it's worth every cent. On my Spec V install the flywheel was dead on and the PP needed a 1/4" nut welded on. The machinist said it was only out minimally. What was interesting was he said that the balance changes on some PP as as the rpm's go up, and that really makes them a bitch to balance, and that they are never fully balanced at all rpm's.
Old 08-23-2006, 12:54 AM
NVR_SPDS's Avatar
Bought my LS6 clutch/PP balanced, but i would have had them balanced any way.
Old 08-24-2006, 06:08 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
You should always balance your FW/PP assembly. You've got the whole god damn car apart... Take 2 minutes and pull the flywheel off. It takes all of 10 minutes for a machine shop to balance it.
I used my factory flywheel/Spec 3 clutch. It just took a little grinding of the PP and it was mint.
I hate half assed short cuts like this...
Old 08-25-2006, 12:20 AM
kenkaru's Avatar
BAD ***, where did you get yours balaced? I'm from Derry.. lived in Hudson for a short time too. I'll be back in NH in two years and it'll probably be time for new clutch by then so I'd like to get it balanced since it's probably a good thing to do. Odd that we've been members for 4 years and I never noticed your location. Nice car. Those are the best rims for Fbods
Old 08-25-2006, 04:58 AM
98camaroLS1M6's Avatar
no, just bought a new one and new pp and it was perfect, I shift around 6800.
Old 11-07-2006, 11:38 PM
SladeX's Avatar
The LS2 flywheel and LS7 clutch seem to spin to 6krpm quite smoothly. Heck even better than the old stock LS1 clutch...
Old 11-08-2006, 03:39 PM
Kleeborp the Moderator™
MeentSS02's Avatar
My RPS clutch came pre-balanced, and there were machinist's marks on it to line up the flywheel to the pressure plate the exact same way they were balanced (since they weren't each zero balanced).
Old 12-27-2006, 05:46 AM
CK1
CK1's Avatar
just bolted up new LS7 clutch and drove!
Old 12-27-2006, 08:57 AM
Gsxrjack's Avatar
I had my LS7 clutch kit/flywheel balanced just for peace of mind on my C5, after such a big job to do i would have shot myself if I had a big vibration after it was done and all back together...
Old 12-27-2006, 04:28 PM
kookamunga's Avatar
normally I would but being that my next Autox race is a week away I was pressed for time. hopefully things work out ok
Old 12-27-2006, 06:38 PM
BMW ///M Nerd
As they say, half-assed = half fast.
Old 12-27-2006, 08:23 PM
Tiago's Avatar
never have balanced one. Stage 5 spec with 25k miles holding up 1000 rwhp now, rev to 7000 rpms....
Old 12-28-2006, 08:13 PM
greysteel_M6's Avatar
I wasn't aware you could balance the two. Is that something a regular machine shop can do? Where can I get that done?
Old 12-28-2006, 09:12 PM
kookamunga's Avatar
yea I hear ya man. got about 50 miles on it so far and funny thing is it feels no different than the stock one did so I guess that's good lol. gotta start racking up ehough brake in miles before the race as soon as it stops raining. V710's don't like water lol
Old 12-28-2006, 10:04 PM
396D1SS's Avatar
tiago that car looks sick from the front.... i like.......
Old 12-29-2006, 02:53 PM
Jimmard's Avatar
My textralia came already balanced. I think it'd be wise to have it balanced.
Old 12-29-2006, 09:03 PM
cam
cam's Avatar
Well interestingly enough this is the ( cant remember exactly now too many beers as I am celebrating engine install tonight )
anyways this is the "many'eth" stick car I have owned and my second six speed.
I have never in the past sent out a clutch/flywheel for balancing BUT I have run a few set ups the required proper installation re alignment relationship between p plate and flywheel and whatnot. Two that come to mind were a Hays set up i ran on a muncie backed low 11 sec 6700 shift RPM 427 Nova and it was smooth as silk and second was an LT1 t56 behind a mild 13 second carbed 350 in a camaro I built. I used a stock clutch and came to learn the hard way that there are yellow paint "daubs" on the flywheel and p plate that you have to match up as closely as possible for correct balance. Of course i was ignorant of this at the time and it had a nasty shudder around 3500 RPM. After many dealer inquiries ( no web access for me in 95 ) I found out about this paint marking business and corrected the installation issue and all was well once again.
That brings me to tonight in which I installed an LS7 clutch and there are paint markings all over both the flywheel and p plate and nothing really matching info I learned on the LT1 style t56 nor anything i could find searching LS1tech or any google hits so I guessed. Please see post here for more info;
https://ls1tech.com/forums/manual-transmission/631752-ls7-paint-marks-flywheel-p-plate-wtf.html
So as far as balancing concerns go and considering the many here who have/are using LS7 set ups I would really like to know the scoop on this. Otherwise my vote is balancing is never bad that I can think of but I have never balanced a flywheel and clutch together. Many set ups and never had issue aside from said t56 problem.
Old 12-29-2006, 10:30 PM
JRracing's Avatar
I would want it balanced. I just pulled my tranny and the clutch looks pretty smoked. I plan on getting it freshened up and re balanced.
I would think that its a MUST DO kinda thing.
Quick Reply: M6: Did you balance your FW+PP?
