need a steel flywheel-what kind?
recently started drag racing my 99 ss which has a mcleod single disc and aluminum flywheel and its boggin hard off the line so i think i need a steely. anyone know what kind will work with that clutch beings its impossible to get ahold of mcleod?
High-quality flywheels are Blanchard-ground to ensure that the friction surface is flat and parallel to the crankshaft flange. Lower quality flywheels are surfaced on a lathe. Ram flywheels are Blanchard-ground. I don’t know about Spec.
