clutch master help now!!!!!
whats the best way to get the clutch master cylinder out...im stuck between a steering shaft and a hard place!!! in the middle of the install now and need help...
thanks
thanks
Disconnect the line to the slave, remove the screw that holds the reservoir in place, disconnect the linkage under the dash, remove the two u-bolt nuts from the inside and push the u-bolt out, reach under there from the engine compartment and pull that sucker out.
You need to tell us more specifically what your problem is to get better advice.
sorry, i had it all disconnected. i just couldnt get it finagled right to get it to slide out. the hose from the reservoir to the master was also wedged behind the brake booster and i was worried about cutting it out trying not to get brake fluid everywhere...
i got it though...finally. thanks for the help anyways...
-cam
-cam
