short stick keeps coming loose??
Old 09-02-2006, 01:58 PM
andypz28's Avatar
Default short stick keeps coming loose??
recently installed the pro 5.0 and lou's short stick, no complaints except that every now and then the bolts holding the stick in place keep coming loose and the stick gets loose.
anyone else have this problem?
Old 09-02-2006, 02:02 PM
slowscott's Avatar
I had this problem once. Then I reinstalled it with loctite, lock washers and then wrapped it with duct tape. Hope that helps.
scott
Old 09-02-2006, 02:51 PM
Jimmard's Avatar
scott
That's a little excessive. Just put some blue loctite on the bolts and that should do it.
Old 09-02-2006, 03:00 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Lol, yeah loctite works great on it's own without lashing a rope and duct tape with super glue!
Old 09-02-2006, 04:20 PM
slowscott's Avatar
The stick nearly coming off in my hand may have made me a bit paranoid.
Old 09-02-2006, 05:01 PM
ski23's Avatar
had same problem, threw some blue loctite on there and hasnt come loose
Old 09-02-2006, 05:02 PM
SuperSport4life's Avatar
No problems here I have the same setup and I pound gears like a gorilla I guess you didn't install it right??
Old 09-02-2006, 05:18 PM
andypz28's Avatar
i guess everyone else who responded didnt install it right??
loctite it is!
Old 09-02-2006, 05:45 PM
nickls1's Avatar
Yeah the same thing happened to mine. I never put loctite on it though i just keep tightening it up. Maybe next time I do it I will spring the 4 or 5 dollars for loctite.
Old 09-04-2006, 01:55 PM
andypz28's Avatar
loctite is on, lets see how it works
Old 09-04-2006, 03:09 PM
Element's Avatar
Blue Loctite fixed it for me. I made the mistake of only putting it on the top bolt the first time, and had to go back and do both bolts about a month later. Been quite a while since then, and it's still as solid as if it had been welded. I yank the **** out of it, too.
Old 09-05-2006, 07:40 AM
m6speed's Avatar
mine came loose just recently, i just put some loctite on it and it's been good ever since
Quick Reply: short stick keeps coming loose??
