Clutch stays on floor.
Old 09-05-2006, 05:07 PM
JRWONG's Avatar
Default Clutch stays on floor.
I have a '98 camaro 3.8 V6. Just bought it a few weeks ago. The cluch stays on the floor. I have to get off and pull it. It has done this a few times. Should i be worried? Is this an easy fix?
Old 09-06-2006, 09:56 PM
JRWONG's Avatar
Help!
Old 09-06-2006, 10:13 PM
Z28Venom's Avatar
Does your master have fluid in it?
Old 09-07-2006, 12:47 PM
CARTEK Racing
WS6TransAm01's Avatar
This used to happen to me when I would overheat the stock clutch with a Heads/Cam pass at the track. I would have to put my toes under the pedal and pull it up, pump it and few times and then it would be fine.
Your clutch fluid is shot and overheating. Change the fluid in the master and you should be fine.
Old 09-07-2006, 04:23 PM
JRWONG's Avatar
Yes it does have fluid. Just replacing the fluid will help? Do i need to bleed it?
Old 09-07-2006, 04:31 PM
Z28Venom's Avatar
You may need to have your slave cylinder checked out. I'm not even sure if it's possible to do the slave mod or if the V6 even requires it.
Old 09-07-2006, 04:39 PM
96lt1m6's Avatar
from what i have been seeing you will be getting a new slave cyl. soon.
Old 09-07-2006, 06:33 PM
nickls1's Avatar
Chances are the hydraulics have never been changed in it. You should go ahead and replace the master and the slave. Its a bitch to do but it solved my problems.
Old 09-07-2006, 10:15 PM
Black FormulaLs1's Avatar
+1 change the slave anad master then bleed the hell outta the slave..
Old 09-08-2006, 08:36 AM
JRWONG's Avatar
Thanks for you help!
Old 09-08-2006, 09:13 AM
JRWONG's Avatar
I’m looking for parts. I would like to replace clutch assembly, master & slave. I can’t find performance parts for a 3.8L. Any idea where I can buy them? Also, I’m hoping to mod the 3.8L in the future and add a supercharger.
Old 09-10-2006, 02:07 PM
1SickWS6's Avatar
What is the slave mod??
Old 09-10-2006, 10:45 PM
bigdcustoms's Avatar
All you need to to do is replace the clutch master cylinder and bleed the system. This will fix your problem without breaking the bank. You do not have to replace the clutch and the slave cylcinder unless it is slipping.
Quick Reply: Clutch stays on floor.
