Is there a special flywheel to put a T56 on a 6.0? Stock one won't work...
Well, went to put the flywheel on the 6.0 today and noticed that the crank sticks out about an inch (1") farther than the LS1 crank does. Flywheel would not even come close to matching up with the starter not to mention the issues of putting the trans on.
Is there a flywheel that can be bought for putting a T56 on the 6.0 that has the crank that sticks out the back???
Ryan
Ryan
You don't have the 6.0 that the crank sticks out the back of the block about 1/2-3/4 of an inch then, do you?? If you bolt up the flywheel, the starter would not even be able to engage as the flywheel sits too far back....
