clutch issues
clutch issues
having problems with my cutch. i always have this same problem and didnt have to worry about it because it was under warranty.
ok well when shifting fast the clutch sticks to the floor.. also when the clutch does pull off fine you can only feel about a 3/4 on an inch leweigh.
need help.. what does this mean?
If you have higher miles or have done some significant power mods, it's probably time for a new clutch. It could be a sign of hydraulic problems but usually when it starts to happen after modding, the clutch can't handle it and needs replaced with something stronger.
