B&M Short Throw
Old 10-03-2006, 12:28 PM
LT1wannabe's Avatar
Default B&M Short Throw
Does anybody know how much shorter the B&M short throw shifter is than the stock shifter? I'm doing my interior in Sparco, and their shift ***** make the shifter look way too tall because of the way the threads are. Or does anybody know of any short throw shifters that are much shorter than the stock version? Thanks.
Old 10-03-2006, 12:42 PM
Hugger Z's Avatar
There are plenty of short sticks out there (Lou's, UMI, etc). Check the manual Trans section for the info. Not sure if they will bolt up to a B&M though. Research in that forum for your answer.
Old 10-03-2006, 04:45 PM
LT1wannabe's Avatar
Thanks
Old 10-03-2006, 11:11 PM
LawmanSS's Avatar
You should have better luck in this forum.
Old 10-04-2006, 07:35 AM
Kleeborp the Moderator™
MeentSS02's Avatar
It isn't too much shorter than a stocker, and a lot of people don't like that. If you need to switch out the shifter handle, then the Pro 5.0 is for you.
Old 10-04-2006, 03:55 PM
dailydriver's Avatar
I have a Sparco anatomic (pistol grip indentations) suede **** on a cut down (about 1") Pro 5.0 handle and it is about perfect. But it is NOT a threaded ****, it uses 3 allen keys to secure to the handle.
