Grinding going into 3rd after clutch install
Old 10-05-2006, 01:54 PM
Adam_LS1_Z28's Avatar
Default Grinding going into 3rd after clutch install
Hey guys i just installed a Ls6 clutch and slave and we just got done bleeding it with the mighty vac. Well took it for a test drive and it goes in every gear just fine except 3rd it grinds when i put it in. Now before the install the tranny was perfect no problems at all going into any gear, is there something we did to cause this or does the clutch need to be blead more?? Its really pissing me off
Old 10-05-2006, 09:07 PM
I am thinking it could be that it's still not blead right cause when i punch it and try to shift its hard to get into gear and then the clutch doesn't come all the way up. On my way home it went into 3rd without grinding twice, can air in the line cause my problems??? Someone please help.
