Very tired of changing clutches!!
Old 10-12-2006, 05:45 PM
SSDION's Avatar
Default Very tired of changing clutches!!
Hi,
I've tried stock, CF 12'', Spec 3 and clutch is still splipping badly again!! Only 20 low 11's passes at the track with 6500 rpm clutch dump, 1.50's 60' with 28x10.5 MT ET Drag slicks The Spec 3 was installed with the supplied shim, 02 hydraulic and resurfaced flywheel. Which clutch would you get for a full weight car with good power and torque?
I was thinking about a different design than the Diaphragm with very high pedal pressure. Maybe a McLeod Borg n Beck Long style with a Drag Racing Bronze Disc? Anyone have experience with these?
Duals are very expensive but maybe this is the only solution to my problem?
Thanks for your advices
SSDION
Old 10-12-2006, 07:57 PM
Phil'sC5vette's Avatar
Dont dump at 6500 RPMS
Old 10-13-2006, 12:05 AM
ls1amit's Avatar
dumping on slicks at that high of an rpm might do it. i say spec stage 5 or 4 at least. and where is your clutch engaging cause you might want to look into an adjustable master cylender.
