pressure plate bolts!!
If all of them are backing out, it's very serious.
What makes you think they're backing out? Did you bolt up the pressure plate yourself? If so, did you torque to spec, and use the proper torquing sequence? If you did, I don't see how the bolts could be backing out. If one of them is, the remaining bolts should be able to hold the assembly together, provided they were torqued to the correct spec, which, if memory serves, is 52 ft-lbs.
If all of your bolts are backing out, you've got problems, and you'll know it immediately. Your pressure plate will back out as far as the bolts let it, and you'll have nothing keeping your clutch disk between your pressure plate and flywheel. Disengaging the engine from the transmission will become impossible. You'll hear all kinds of interesting noises. I've never really looked at this, because I've never thought about pressure plate bolts backing out, but if the bellhousing allows the pressure plate to back out far enough so that the pressure plate can back off of the flywheel dowel pins, well, I don't even want to imagine the mess that would make. I think the bolts backing out would give you plenty of problems before things got that far, though.
Originally Posted by white99
the disc wont go anywhere. it's held in by the transmission shaft
