View Poll Results: Mcleoud or Textrilla?
Mcleod Twin Disk
60
41.96%
Textrilla Exoskel
83
58.04%
Voters: 143. You may not vote on this poll
Hey guys give me some feeback. Ive heard great things from both. It would be comparing the Mcleoud twin disk clutch to the Textrilla exoskel. Thanks for the input.
So what is the difference between an organic and a metallic disc? Which one would hold more power is what im tryin to say? I dont really care about changin the master cylinder cause that probably needs to be changed soon anyway... Seems like every dam part on my car is needing to be replaced nowadays...
I honestly don't think that any clutch setup behind some decent power should use the stock master cylinder. I have the OZ700 and it has been flawless for ~10k. I did however have to upgrade to the Mcleod master after the heads/cam. The stocker just wasn't up to the task. So I wouldn't plan on saving money by using the stock mc with the TEX, just get the new mc no matter what you go with, but TEXtralia has my vote.
6600 rpm clutch dump of death Administrator
We ran a Mcleod dual disc. It did use organic discs. The issue I've seen is that with all the mass in the flywheel and Pressure plate you cannot powershift a car with a McLeod Clutch. The McLeod setup we had was around 65 pounds if memory serves me correctly.
Originally Posted by J-Rod
The stock hydraulics are more than up to the task. Textralia specifically states not to use a McLeod adjustable as it has a differnet fluid volume and travel than a stock clutch. A McLeod adjustable will used with a Textralia clutch can damage the clutch and cause overtravel.
I've sent several emails to Tex and I'm still waiting on there response. I will be approaching 750rwhp next year and wanted some info on there dual and single-mainly which is up to the task of a daily driver and then launched on ET streets at the track. I mainly wanted to know if the new dual will work with the stock hydraulics-ie not adjustable master and if the dual is available with a aluminum flywheel.
i have a mcleod twin, and i will never go any other way. been through a couple different ones. although not a tex. but i can say the mcleods customer service is the best!
plus its just as streetable as stock imho
The dual uses stock hydraulics.
The dual is not avaliable at this point with an aluminum wheel. With its lower MOI, its really not necessary in our opinion at this point. Nathan Higgins is turning his motor over 8700 and shifting a stock type T56 with our dual disc clutch in his car.
The Textrilla Exoskel held perfectly on my car's 9.98 pass this weekend. I'm pushing over 800 RWTQ on my nitrous motivated C5R blocked 427. What's impressive is I'm running 373's with 28's...now that's a load especially with a big fat vert.
