Clutch Bad? (Spec Stage 3 Lightweight)
Have A question for your guys
Clutch doesn't feel like it fully disengages. I've bled the clutch assembly a few times, flushing it out clean and everything. Every once in awhile it feels fine, from a stop engaging normally, then say the next stop it would engage slowly and not fully disengage having my foot completely off the clutch pedal accelarating as the car slowly engages. it has never smelt. and has always engaged with no problem, right as all this happened the clutch was not as stiff as it was before. also while in 4th, 5th or 6th gear giving it to much gas will cause it to slip really quick.
cars never been launched, ran at the track, mainly driven to work with equal amount of street and freeway use.
I have alittle over 500hp in motor
and it's only been in the car for 4 months
i was think the pressure plate has failed?
whats your guy's thoughts on this.
Thanks
Thanks
