how good is the t56?
I am trying to find out how much high rpm shifts the car can take on the stock T56 and how much power it can handle before it breaks? thanks for any responses.
Ive heard of people with 850+ horse running stock t56's and still abusing them. It has a lot to do with having a good clutch that saves your tranny from grinding gears and what not.
mine went bad along with my clutch and flywheel but that was with alot of abuse and powershifts. So now i have spec 3+ on the way and got a new gear set along withsome upgrades from t56rebuilds.com
Originally Posted by TOSTO RACING
All of my parts are stock nothing upgraed in my trans. I still run the plastic fork pads.
They are stonger than you'd think
Originally Posted by GC99TA
One of the most important things to making these things last is getting the torque arm relocated off of the tailshaft housing.
the t56 is quite good in my own opinion
on of the s-sereis guys did this to his stock nv3500
he is now running an aftermarket t56 and running 11's in the 1/4 with no problems
seeing his trans failure was enough to make me switch to a t56, i dont need to loose a leg cuz i scattered a tranny
