Spec stg3 owners inside
Forgive me if the other threads have the solution but I just installed the spec stage 3 clutch in my 2000 SS and i dont know if its not engaging all the way or what but it will not go into a gear at a high rpm. Slave cylinder need to be upgraded? Any solutions?
thanks guys
Corey
thanks guys
Corey
BMW ///M Nerd
#1 Did you use the supplied shim?
#2 How many times did you bleed? And what method did you use?
Everyone complains about bleeding the hydraulics in our cars. I bled my system by hand (no mityvac/ air powered bleeding) and it was mint from the get go.
1 Snap on adjustable head/locking 1/4" ratchet
1 Snap on 7/16 1/4" socket.
Guy up top working the pedal, open close bleeder.
I don't know what the big problem is...
