clutch gone
clutch gone
i think my clutch is done. when i press the clutch down it goes down very easy and i really can't change any gears unless i force it. anyways if it is where can i get a good clutch.
drivers side under the hood you have your brake fluid that holds brake fluid and closer to the fender well there is a small plastic clutch fluid. mine has a black cap see if it has any fluid in it or if it looks black.
theres a big one with black fluid and a little one with nothing in it, but it looks like there was black fluid before. also when i use to take off there was a rattling noise everytime. and now that i turn the car on stinks like smoke but u can't see black smoke coming out of the exhaust
that is the first part of your problem. The small one is your clutch fluid and should not be empty. I think i would start there. Fill it with fluid (dot 3 brake fluid) and bleed the clutch. There is a thread here titled "powerbled my clutch today great results" I think thats the title, anyway try that first and if that doesnt work we will move to the next thing
Before you buy the power bleeder, you might just want to try and bleed the clutch manually; like you would your brakes. There is a bleeder valve about 2-3 inches above where the hydraulic line goes into the trans.
I bled mine this way this evening after I put a new clutch in the car, and it work fine. Took about 10 minutes, with a buddy.
hey its free why not! personally i tried it and it takes foreverrrrrrr!!!!!!! and can be frustrating. the power bleeder will flush all the old fluid which you probably need to do anyway. its just easier and i had much better results
I just bought a new master cylinder and slave cylinder with the clutch but only replaced the slave cylinder. Since the master cylinder came pre-filled with fluid I plugged it up to the slave cylinder before installing it, opened up the bleeder valve and just gravity fed fluid into it. Then just installed the new slave and kept the new master on hand to replace later-it looks pretty easy to install, unlike the slave cylinder which of course requires removal of the clutch. sanity check on this anyone? *edit* but thats just if your changing out the clutch, not bleeding it on the car like your trying to do
well the mighty vac fixed the problem, now how do i know when a clutch is going bad, someone told me that my clutch was going out because they heard rattling when i was taking off
