t56 yoke?
t56 yoke?
i have a t 56 and i want to know if i can install a yoke that does not slip in the trans so that i can have a drive shaft made that slips in the center the tranny is bone stock
Are you talking about using a fixed flange? There is a thread in the end of the mainshaft that you could use to fasten a flange or yoke. Sealing will be a problem but not impossible. To use a flange, you will need to "face " the end of the shaft so it is truely perpendicular to the spline. This step will rquire you to dis-assemble the shaft for rework.Have you looked at a CTS-V T56? It is already set up with a fixed flange.
I think they are somewhat avail. aftermarket(used) but new will have to come from a GM dealer. If you were to use a CTS-V box as-is you will also have to deal with the odd shifter they use. It is a floor-mounted semi-remote design.
What does a driveshaft isolator do ??
Only asking, as Ive never seen a 1 piece shaft that had a slip yoke in the middle.
And if its balanced...its balanced ???
Not so sure we are talking about the same thing.
Most cars over here...have indepentant suspension at the rear, which means the diff is fixed.
So actual slip movement required by any driveshaft is very limited, if any at all. The only movement would be to allow for engine/trans movement, as the diff will not move fore and aft like a live axled car would, as it moves up and down.
Most Euro type ( and indeed jap ) use a 2 piece driveshaft ( as I am using )
True, a lot of them use a CV type joint in the middle, or a tripd type joint, similar to many front wheel drive cars driveshafts ( axles ) so this would allow some degree of sip movement.
If you are seeking something for a high power situation...I dont believe that is the route to take.
I have a 2 piece shaft with a 1350 slip yoke just after my centre bearing. Due to shaft length, and packaging, I had no choice but to use a 2 piece...
That same slip yoke is a major cause for concern for me, as I do fear it wil break.
I have a regular front section with slip yoke which take me to a fixed centre bearing..and then a 2nd slip yoke in the shaft to allow for axle travel/movement. ( pictured )
I dont particularly recall seeing too many 1 piece, slip jointed shafts on production cars.
2 piece yes, 1 piece no.
Virtually all Euro type cars I have seen, all use 2 piece shafts with a centre bearing.
