Black fluid
Black fluid
I had my stock clutch replaced with Centerforce and I did slave syliner at the same time, filled up with new Dot3 fluid.
Recently checked and fluid is dark , more like clear/black.
Checked my brake container - same : dark/black
Is it suppose to be like that?
over a period of time, depending on how hard you drive your car you burn the clutch fluid. someone who drives calm and is easy on their car will have longer lasting clutch fluid than someone who goes and beats on their car every chance they get. it is perfectly normal. bleeding your clutch and changing the fluid is routine maintenance.
