LS7 clutch part numbers
I am about to take the plunge and replace my worn spec 3 clutch with an LS7 clutch. I searched through a number of threads and seemed to have found the part numbers needed for the install. Could any of you in the know look over the part numbers I listed and verify whether they are the correct parts and up to date numbers before I continue? Thanks in advance.
12571611 - flywheel
15046288 - slave cylinder
24238412 - LS7 clutch and pressure plate (New part number. Old numbers are 24236500 and 24237690)
14061685 - pilot bearing
12571611 - flywheel
Ok i just got my ls7 clutch kit from fred beans parts. They sent me the WRONG slave cylinder, because you have to use the upgraded hydrolics for this clutch to be fully effecient. The part number you have -15046288 is the part number for the 1996-1999 slave cylinder that is the WRONG slave you need the upgraded one.
Hmm.... I thought that was the upgraded slave part #. If that isnt the correct part #, could you let me know what the correct part number is?
i'm getting the ls7 clutch i checked with my parts guy today and the part number for a 02 camaro with the upgraded slave changes to that number so that is the correct part number.
