My ExoSkel just came in.... pictures
Old 11-10-2006, 03:50 PM
2002/Black/SS's Avatar
Default My ExoSkel just came in.... pictures
first i got to say this is one serious looking clutch, weighs 45 pounds! glad its teh one i decided to get! but i still havent decided if im gonna install it myself.
and textralia, u got any installation advice for me on how to install it correctly? anything special i have to do?
the clutch:
the second clutch disk:
the clutch disks seperated:
top clutch disk:
Flywheel:
Old 11-10-2006, 03:55 PM
BigDB's Avatar
wow nice looking clutch, looks like its capable of honding some seriouse power. I just washed up from taking out my tranny and pulled my spec to see how it looked, not to bad but there is a ring where the material is missing and the flywheel has a groove. Let us know how this clutch works for you, like if it chatters and how it drives. How much you get it for?
Old 11-10-2006, 04:04 PM
Zymosis's Avatar
From what I've heard, make sure you thread lock the pressure plate bolts
Old 11-10-2006, 04:21 PM
trod's Avatar
How Much ?
Old 11-10-2006, 04:26 PM
i got in on the group purchase but its like 1300 i think
Old 11-10-2006, 05:02 PM
1CAMWNDR's Avatar
$1249 from ByunSpeed.
Comes in one hell of a crate too. Here is mine:
Hey 2002/Black/SS, do you see how to keep the thing lined up to maitain balance on reassembly? All I see is one white mark on the pressure plate; nothing on the flywheel.
Old 11-10-2006, 05:14 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
Yes, important if you decide to do it yourself. I loctite the flywheel, and pressure plate.
Sicko looking clutch. I can't wait to see how this one performs.
Old 11-10-2006, 10:50 PM
LS1TECH Sponsor
Textralia's Avatar
Place loctite in the bolt holes, not on the bolt as it tends to get wiped off when installing the bolt through the pressure plate hat.
Torque the bolts to 55 lbs (stock GM spec).
The pressure plate is neutrally balanced, so orientation isn't an issue if you move it. But, try to keep it the way we sent it if you can, and the hat is usally set up "best" the way we send it.
Line the discs up so the plates are in line with one another, and the pucks aren't off a few splines. This allows for consistent loading on the clutch.
I am including pictures to ensure you re-assemble in the right order. They are numbered 1-2-3-4. The clutch discs should be marked also.
Other than that, follow our normal procedures outlined in our normal clutch installation documentation which I have also attached.
Attached Thumbnails My ExoSkel just came in.... pictures-1.jpg   My ExoSkel just came in.... pictures-2.jpg   My ExoSkel just came in.... pictures-3.jpg   My ExoSkel just came in.... pictures-4.jpg
Old 11-11-2006, 08:19 AM
hugger427's Avatar
you'll love it. I pound on mine with over 800 RWTQ and it wants more...great product!!! Great on the street too.
Old 11-12-2006, 11:29 PM
sdiddy's Avatar
My Spec III is crapping out on me, so I am going to buy this clutch. It works with the stock hydraulics, right? How tough is this bad boy to install?
Old 11-13-2006, 07:45 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Is that ARP fasteners holding the clutch to the flywheel?
Old 11-13-2006, 01:02 PM
DONAIMIAN's Avatar
At 45lbs its a good bit heavier than what I would have thought it to be. That and it dosent apear to be rebuildable.
Old 11-13-2006, 05:11 PM
stevieturbo's Avatar
Tex...whats the idea behind having only one sprung, and one solid plate ???
Can you get both plates sprung ?
What weight is a stock clutch setup ?
What isnt rebuildable ? im sure the friction surfaces can be re-cut, and new friction linings fitted to the plates.
Id like to hear a few more reports on how it drives etc. I might upgrade soon.
Old 11-13-2006, 10:16 PM
bayer-z28's Avatar
45lbs is light in my book. My stock setup had some weight to it. My McLeod was quite heavy, also. Must have been 60lbs.
Sick looking clutch. Of course I allways find a better one after I install mine. Oh, well. My Single disk will be good for a while. I won't be pushing 700hp any time soon anyway.
Old 11-13-2006, 10:19 PM
RoastEmSS's Avatar
wow that thing is bad, this will def be top contender for my next clutch
Old 11-14-2006, 11:45 PM
LS1TECH Sponsor
Textralia's Avatar
The mass of this clutch is closer to center, and thus a has a much lower MOI than a comparable single disc of larger diameter but of the same weight.
As for being rebuildable, the unit is quite rebuildable... We've stated as such before. The entire unit is designed to be serviceable and rebuildable.
Old 11-15-2006, 01:59 AM
BuBbABFP's Avatar
Id love to buy onem but its too pricey for me. =(
Old 11-15-2006, 12:09 PM
Tex...can you answer my question please ?
Whats the idea behind having only one sprung, and one solid plate ???
Surely both plates will clamp at the same time....so any spring effect, just wont happen ?
Old 11-15-2006, 01:28 PM
LS1TECH Sponsor
Textralia's Avatar
Stevieturbo - The clutch works great with one sprung plate.
You can not get the dual disc with two sprung plates.
If you have any other questions, you can drop us an email @ admin@textralia.com.au
Old 11-15-2006, 01:38 PM
Senior Member
Country Boy's Avatar
It looks like one badass setup. I wanted one for my turbo setup, but they werent out yet when I bought the OZ700
Quick Reply: My ExoSkel just came in.... pictures
