Tranny / clutch issue PLEASE HELP !!!!!
Hi there fellow ls1er's. I have a 2000 z28 m6 . My problem is that i am getting a slight grinding type of sound when i shift into gears. ( NOT certain gears) It does not do this all the time. It is also harder to shift into gears. ( NOT all the time) Somtimes it is both hard to shift into gear and also makes the grinding type sound at the same time. Every once in a while when i have it in neutral with the clutch pressed in ONLY i hear what sounds like light metal to metal grinding kind of a screeching sound. This only hapens when the clutch pedal is pressed in. The sound kinda changes as i let the pedal out. These sounds are coming from where the clutch assembly is ( SO I think). I hope you guys can help me. I did the drill mod and bled the master/slave cylinder and that did not help. Also changed the fluid in the clutch master. I have been told it is deffinitly the pilot bearing and or the throw out bearing ???? The car is sitting now for 5 days since i dont want to harm the tranny.
Thank you !
Thank you !
it only makes the screeching sound when the clutch pedal is pushed in. My last transmission started to get really stiff to shift into gears even with the car off. I didnt change the clutch when i swapped trannys i just took the tranny off from the bellhousing. COULD it be somthing i didnt change then ?Also the car used to pop out of 3rd gear for about 2 weeks but now ( knock on wood) doesnt do it anymore. Now since i have bled the slave the clutch doesnt engage untill the pedal is almost all the way let out. I am pretty sure i got all the air out. It got stuck in 4th gear about 4 months ago when i was racing also .then another time i was trying to race a vette on the freeway i down shifted at high rpms then it wouldnt let me go into any gear kinda was stuck and grinded wherever i tried top put it ?Just thought this might help you guys help me.
Thank you !!!!!!!!!
Thank you !!!!!!!!!
Thank you for replying Mike44138 ! So do you think that by me replacing the parts listed above it should fix my problem ? What should i look for when taking the clutch,flywheel and disc off ? Also is there a write up on how change out a clutch ?
Thank you !
Thank you !
http://www.installuniversity.com/ins...sity/index.htm
theres a nice clutch install guide for you good luck.
Well i just ordered the ls7 clut clutch kit- clutch disc,pressure plate,ls7/ls2 flywheel,pilot bearing and slave cylinder with throw out bearing for under $600
Thanks guy's hopfully this will fix my issues.
