Changing Clutch Fluid
just wondering when a good mi/time to change the clutch fluid is. I have a 99, its had the tranny fluid changed, but not the clutch fluid. car has roughly 35k mi and i believe original clutch fluid/brake fluid/p. steering fluid. thinking i might get it ALL done at the start of next yr
I change mine twice a year. I just drain the old fluid out of it by opening the bleeder and pushing the pedal down to the floor and holding it there. Then have the bleeder closed. I repeat this until I am just about out of fluid. Then I top it off and continue this process till I am almost out of fluid again. This way you don't pull any air into the system and you are flushing all the old stuff out of the system.
