Donato Engineering (T-56)
I personally know the owner of this company and he does extremely fine work. his main service is the Viper output shaft conversion, he also offers a cryo internal service as well as some different gear ratio options. Fork pads can be upgraded to a much harder material. Many other options avaliable
I strongly recommend John and hope you guys appreciate the review
I will be having my (T-56) gone threw by him (I will be doing the work) he will be over my shoulder.
Donato Engineering....Milford MI
since I am just DD the car we are going to do the steel shift forks, examine the syncros and all pieces and upgrade the pad of the forks. and just make sure everything is in good working order. also upgrade the fluid to the new viper fluid to get ride of the gear set noise that sounds like a bad throwout bearing! John said the new fluid shuts it up.
Since you did say dailey driver, I would steer from the Viper fluid. If its the Castrol Syntorq LT that I know of, It will be too thick for winter driving( generally not a Viper owners concern). You will have much harder morning shifts that you experienced with the correct ATF fill.Save the $$ and get a plain ol Dex III ATF, like your manual states.
Kleeborp the Moderator™
Originally Posted by 1INSANEGTO
I have to get mine upgraded once it blows. Since T56 rebuilds is local to me then thats where I will be going
BMW ///M Nerd
Originally Posted by MeentSS02
They certainly treated me well...their transmission is about the only thing I'm happy with in my car right now. The rear end is on its way out, and my LS1 is...well...stock.
I feel you... I've got a blown T56, and a BEAT rearend. Bolt ons are great, but don't compare to what I'd like to have done to the car.
All in due time.
I've got some Torco ATF sitting behind me right now that'll be going in in a couple weeks for grins...just wanna see how it does compared to the Mobil 1 ATF in there now.
