Help me out with a bleeding question!!!
Ok I just installed my new clutch, slave, t/o, pilot, pressure plate and flywheel. Put in fluid and ofcourse there is no clutch at all until I get the air out. My question is...how long will it take using the mighty vac until I have clutch pressure. What if I don't receive clutch pressure? I replaced everything at 93k because my slave blew out (so I assumed because dot3 fluid was draining from the trans/bellhousing vent). Any advice...?
