Clutch Fluid / Pedal
Old 11-20-2006, 10:21 AM
Jayh's Avatar
Default Clutch Fluid / Pedal
Everything is stock except the Spec Stage 3 I've had for over a year......I mity-vac the resevoir and cltch is fine......over time I lose the clutch and the fluid. I have headers but the lines are heat shielded......I think there might be DOT 3 coming from the slit in the bottom of the tranny.........and ideas? Thanks in advance.....
Old 11-20-2006, 11:27 AM
98 SNAKE EATER's Avatar
Well, if it's coming out of the bellhousing, it's either a leaking slave or a loose bleeder valve...
Just curious, did you install the shim with the Spec3?
Old 02-26-2007, 07:45 PM
Jayh's Avatar
I dont think the shim was installed. I didnt install it so not sure. I about to go buy an 02 slave from NAPA and dig into the tranny for th 1st time. Hope it fixs it.
Old 02-26-2007, 10:47 PM
Xtnct00WS6's Avatar
Sounds like the bleeder valve is loose.
Old 02-26-2007, 11:03 PM
00BlueTA's Avatar
I would check the bleeder befor I pulled out the trani, Its a quick check that might save you a few hours of work.
Old 02-27-2007, 11:57 AM
SPEC-01's Avatar
Default Make sure...
Make sure you check the disc while the trans is off. If you have had fluid in the bellhousing then there is a good chance that the disc is contaminated. It is always better to check then not. Thanks,
Quick Reply: Clutch Fluid / Pedal
