clutch package
clutch package
hey i been out of the loop for a bit..car garaged....last i remember we were doing
the ls6 clutch with the ls1 flywheel and updating the slave to the 2002 slave
so whats the approved GM parts for the next big thing in clutch set-ups
part numbers would help me out too please...need a clutch to get the car on the road again...1998 ws6
kool thanks
found this
LS7 Clutch Info
The LS7 clutch will fit any LS1/LS6/LS2 powered vehicle but must have the Corvette LS2/LS7 flywheel. Please keep in mind you must use the updated hydraulics for your make and model of vehicle, not LS7 hydraulics. The LS7 hydraulics do not work! Here are some part numbers to assist you in getting the right parts. All of these part numbers are under Chevrolet make.
Part number ls7clutchkit
Includes ls7 clutch disc, pressure plate and flywheel.
Part number 14061685
New pilot bearing for any of the Fbody or C5 models.
Fbody (Camaro And Firebird) Components
Part number 15046288
Updated slave cylinder
Part number 12570277
Updated master cylinder
found this
LS7 Clutch Info
