T 56 clutch hose
T 56 clutch hose
Any tips on how to un-couple the master cyl . to throw-out bearing hose at the gold connector ?? A special tool ?? Any home made tool tips ??
You'll need to open the bleeder screw and uncap the reservoir to relieve pressure. Use two flat head screwdrivers to push down on the white plastic ring. You'll have to use a little bit of force, but it'll click and then separate and you can then pull it out.
