What clutch is best?
I have a s-10 with a t56. all the swap parts used are from a lt1 camaro. Now, my current clutch is a stock camaro clutch, and its about to go. But, eventhough it is a stock clutch, the pressure on the pedal is horrible because i still have my stock truck master cylinder. A v8 on spray is going in it, so i need a good clutch, flywheel combo, that will hold about 500hp and have as close a stock pedal feel as i can get. because my clutch pedal is hard, and i dont want it any worse. What flywheel/clutch do you recomend? i was looking at the mcleod twin disk.
