Hard to go into 1st
Hard to go into 1st
It's getting pretty hard to get my car in first gear. Every once and awhile it will slide right in but most the time I either have to really push it in. Sometimes it helps to got N to 2nd then to 1st and it slides right in. Sometimes it helps if I pump the pedal a couple times before going to 1st. What causes this? Am i looking at serious tranny problems?
Thanks
Jon
Thanks
Jon
Check fluid level. There is a pipe plug on the left/upper of your transmission, it is "fill to spill". I had jiffy lube check mine, they did it for free and I tipped $5 b/c the let me under the car and checked diff fluid and let me look at the U-joints and all.
