I Am Bleading To Death!!!
I changed my cluch and slave cylinder to day and can not get any pedal pressure what so ever...i have bleaded the system time and time agin and cant get no where w/ the pedal pressure
lol @ the thread title.
How much exactly have you been bleeding, and more importantly, how. Your system should go like this -
1. Clutch resevoir should ALWAYS be full during bleeding - if you let it run dry you suck air into the system and need to start all over again.
2. Depress clutch pedal
3. Open bleeder screw
4. Close bleeder screw
5. Release pedal
I had to do this about 30 times until I had pedal pressure...took about 30 minutes. You could try bleeding with a mity vac also.
5. Release pedal
