T56 Stuck in 4th gear? Help
Old 12-22-2006, 01:36 AM
lasvegasgs's Avatar
Default T56 Stuck in 4th gear? Help
Here is the story im driving down the street in 4th pull up to a stop light and try to get out of gear but it doesnt let me. So I let the clutch out a bit and it lets go. Half a Mile down the road same thing I pull into a gas station and check my clutch fluid level its fine so I keep going. I also get come and its locked in gear good wont let go I didnt force it to bad but it doesnt wana let go. I drained fluid and it looks fine. Pulled the shifter everything looks fine. What can it be?
Thanks for the help.
Old 12-22-2006, 02:15 AM
CaliboyTA's Avatar
could be a bent fork or bad syncros, mine did the same thing, i ended up rebuilding it with D&D peformance synchro rebuild kit, billet keys, and a new 3/4 synchronizer assembly. Been over 8 months and i haven't had any problems with tranny yet.
Old 12-22-2006, 03:16 AM
lasvegasgs's Avatar
Whats something like that cost to do? Its just strange that its only 4th gear and it goes into it fine just wont come out.
Old 12-22-2006, 06:47 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Your tranny is fucked, it will need syncros go to http://www.t56rebuilds.com
I just got done helping a friend with the same issue.
Old 12-22-2006, 12:26 PM
98turbls1's Avatar
How hard are they to install?? I think mine is doing the same thing.. The shifter was physically in neutral but it was in 5th gear...
Old 12-22-2006, 12:43 PM
Internet Mechanic
Rebuilding a tranny is VERY hard if you have never done one, having a press and a good set of snap ring pliers are needed. Having the GM Transmission holding tool or a bench with a hole through it is needed.
The actual Removal of the unit is cake compared to the rebuild
Old 12-23-2006, 12:21 AM
lasvegasgs's Avatar
Here you go guys with the same problem here is the answer.
http://www.torquecentral.com/showthread.php?t=40141
I will be doing this my self in the next few days I'll let you know how it goes.
Old 12-23-2006, 01:27 AM
Alex L.'s Avatar
I had same symptoms you are describing. Could not get it out of gear. Turned out the slave puked.
Old 12-25-2006, 09:42 PM
INMY01TA's Avatar
That happened to mine when it was new. Got it out of gear and it didn't happen again.
Old 12-25-2006, 09:47 PM
slow2000z28's Avatar
happened to me in 4th too... i had to rebuild the tranny. had a prof. do it using parts from rockland gear. no more problems been 10 months
Old 12-26-2006, 10:10 AM
pontiac's Avatar
same gear with mine too, had to replace fork and put billit keys in and someofther goodies have to fix it
Old 12-26-2006, 07:57 PM
BriancWS6's Avatar
Get a steel shift-fork and replace the junk stamped slider keys with billet steel units.
Quick Reply: T56 Stuck in 4th gear? Help
