shifter prob.
i don;t believe it's possible. i had the same problem. i took the shifter off and put it in a vice and used a huge set of channel lock pliers to wrench off the ****.
Originally Posted by Specialized
Its possible, I probably spin mine around every day because I play with it so much.
But I'm pretty sure that your shift **** will be FUBAR'ed by the time you get it off. Once it's stripped, it's damn near impossible to remove.
