and.......The TA breaks down.
so the past few days my clutch has been squeaking sometimes when it is depressed...then the last time i drove it (4 days ago) i could feel alot of vibration through the clutch pedal. Well yesterday the weather was nice so i decided to take it out for a lil bit.. i washed it, put gas in it, and drove about 5 miles, and i was in 4th gear, pulled it out to put it in neutral and it came out really harshly as if i wasnt even using the clutch...i released the pedal and it barely came up at all. i pressed it down again and it was really stiff, squeaked, and i tried to press it down more and i heard a grinding noise so i didnt bother with it any more, and just coasted into a parking lot. I tried to start it about 30min later and it wouldnt even turn over. I also noticed right before it happend i was idling in a friends driveway and with it in neutral without pressing the clutch i could hear a rattling noise that wasnt too loud, but i could hear it over my car with open exhaust cutout. Any ideas on what this could be? I was thinking possible slave cyl, or throwout bearing. Someone else also suggested a bad flywheel. Clutch/trans/motor all have 6k miles on them. and clutch is a spec stage 2. Thanks,
James
James
my mechanic says its the slave cylinder, but now the problem is figuring out what caused it to fail..he says a few teeth could be ruined on the clutch...any ideas? thanks guys
