t56 removed. question
also when i was taking the transmission out a lot of dark brown fluid came out from where i took the driveshaft out. was that transmission fluid. sorry for all the qs? but is my first time taking the transmission out.i'm just replacing the slave. do i need to flush or bleed anything before i put the new one
Fedge got it, that is the vent tube. And yes, that fluid that came out from where you removed the driveshaft is the transmission fluid. It's supposed to be red. When's the last time you drained the old stuff and put new fluid in there?
