Anyone's Master Cylinder squeak
Old 01-08-2007, 01:52 AM
turbologics's Avatar
Default Anyone's Master Cylinder squeak
When you push your clutch pedal do you hear a squek because this thing is bugging me already
Im just wondering - It's a brand new M.C and I don't really want to hear it - I might as well put my old one back in - It could just need broken in - I dont know
Old 01-08-2007, 02:06 AM
TwistedSS's Avatar
Mine has always squeeked.
Old 01-08-2007, 02:16 AM
Good that makes for a goodnight sleep - I didn't know what was going on with it
Thanks Twisted
Old 01-08-2007, 07:31 AM
whiteLS1's Avatar
mine does it sometimes. idk why i wish i did know its annoying
Old 01-08-2007, 07:51 AM
JT LS1's Avatar
I just replaced mine 2 tweeks ago and mine does it too.
Old 01-08-2007, 10:41 AM
DONAIMIAN's Avatar
Mine does, but I dont hear it at all as long as the cars running.
Old 01-08-2007, 11:40 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Mine does as well...my older master did it more than my newer one. Seems like after I bled the system this last fall (I flush it every year), it didn't do it as much. Could just be me too.
Old 01-08-2007, 05:35 PM
Ok I found the problem inside the master cylinder - And also killed any beliefs that the mity vac might flip the seals - The M.C. has 4 o-rings each are normal and can't go anywhere (Even pressured it to 35 in pnds not HG like the mty vac uses as I didn't use it for my pressure test - I replaced the two rings on the cylinder with new ones I picked up at a friends shop and took out the new M.C and put the old one back in and no squeks or nothing - They are just shitty o-rings Wow who knew (What a waste of time)
Quick Reply: Anyone's Master Cylinder squeak
