Locking knob in place, turn wise
Old 01-12-2007, 07:35 PM
pHEnomIC's Avatar
Default Locking **** in place, turn wise
I got a short shifter on my hurst and stock handle. It used to be perfect, when i tightened it all the way, it was tight and aligned perfect. My friend was messing with it and now tight all the way is like 60 degrees off. If i rotate the **** to the correct position, it spins sort of easily and feels sloppy to me. How do i get it so it stays aligned forward.
Old 01-12-2007, 09:11 PM
Element's Avatar
You can make small plastic shims of varying thicknesses, and use those to shim the **** back to the position you want. I actually need to make some for my MBA ****, then loctite it back on.
Old 01-12-2007, 11:03 PM
SSmokin 01's Avatar
What "Element" said. Thin cardbord or paper will work as well.
Just take the **** off. Cut some circles out of the cardboard, paper, or plastic at a slightly smaller diameter than the shaft of the shifter.
Place a few of your "shims" onto the top of the shaft. Spin the **** back on and check it's orientation. Adding or removing shims will change the final position of the ****. It's like using an index washer for a spark plug.
Old 01-12-2007, 11:47 PM
98sskidd's Avatar
hemm, thanks for making this thread! That just solved my problem on mine too!
Old 01-13-2007, 11:22 PM
pHEnomIC's Avatar
Lol such a simple fix, im surprised i didnt think of that myself. Thanks!
Old 01-14-2007, 11:30 AM
fuseone's Avatar
yes and make sure you beat the friend
