does my ws6 have a revlimiter?
Old 01-18-2007, 12:30 AM
ChevyTex's Avatar
Default does my ws6 have a revlimiter?
If I am running through the gears in my ws6 and miss a gear and hit the gas will it bounce off at the redline or will I possibly bend pushrods or something?
noob question im sure but yea
98 stock ta
Old 01-18-2007, 12:35 AM
BriancWS6's Avatar
98 stock ta
Yes you have a rev limiter. In stock configuration it is set to 6200. If you hit it by just revving it up and not shifting in time, you'll be ok. But if you mis a shift, like going from 2nd back to 1st instead of 3rd, then you can very possibly bend some pushrods from a mechanical over rev.
Old 01-18-2007, 12:36 AM
Phlip00WS6's Avatar
There is a rev limiter that keeps the motor from over revving... with it being stock with stock internals I wouldnt worry about bending a pushrod unless you go to 1st instead of 3rd, or 2nd instead of 4th.
Old 01-18-2007, 11:48 PM
ChevyTex's Avatar
aww thats good...eases my mind
Old 01-19-2007, 12:22 PM
TigerWoodsJr's Avatar
I like to check mine to make sure it's there every once in a while
just not on the juice...
