Spec Stage 2 In 6.0 Slipping
I just put the tranny back in from rebuilding my motor and the clutch slips if you are just going and hit in the low rpms, maybe high ones to but im breaking the motor in so I dont know. The clutch looked great and the whole clutch setup only has maybe 5k miles on it. Any help appreciated.
Is the flywheel new? If not was it resurfaced? I only ask to insure that things were handled precisely with install. You should be through with break-in with this much mileage. The only other potential issue would be contamination of the disc. If you want to pull the unit and email me some pics I will be happy to check them out. Thanks,
So, you intalled the clutch and a new SLP flywheel together 5000 miles ago? If I understand this correctly then this shouldn't really be an issue of improper surfacing. Have you noticed any fluid leaks on the car at all? Why was the motor rebuilt? I am just trying to think of this from all angles. Let me know. Thanks,
