View Poll Results: which one?
LS7clutch w/LS2 flywheel
7
58.33%
SPEC 3+ w/LS1 flywheel
5
41.67%
Voters: 12. You may not vote on this poll
Clutch and Flywheel
Old 03-18-2007, 08:36 PM
one2run's Avatar
Default Clutch and Flywheel
looking to do the SPEC 3+. Their website does not specify if you can use the stock LS1 flywheel. Has any installed the 3+ to there stock LS1 flywheels with success?
Also what would you do for a clutch that will see strip launches on drag radials? I am considering the LS7 with LS2 flywheel, or the SPEC 3+ with a resurfaced stock LS1 flywheel.
Old 03-19-2007, 01:01 PM
brad8266's Avatar
You can use the stock resurfaced flywheel provided it is surfaced right and 100% flat. I have the billet flywheel though and thats the way i would go if I had to do it again.
I would go with the spec 3+ for hard launches on drags.
Old 03-20-2007, 06:19 PM
one2run's Avatar
great, I was hoping to be able to do that. one more question. how do I go about resurfacing the flywheel, and what costs are involved with that?
Old 03-20-2007, 06:21 PM
brad8266's Avatar
take it to a machine shop, its probably something like $50
Old 03-20-2007, 06:26 PM
jdaniel's Avatar
It will work with the stocker. Thats what im using (Spec 3+ here). I paid $48 to have it resurfaced.
Old 03-26-2007, 10:19 AM
SPEC-01's Avatar
Make sure that the flywheel is ground and not lathed. Also, after the resurface, lay a straight edge on it to insure flatness. Has you stock wheel be resurfaced before? If so then you may want to buy a new unit...there is nothing worse than going through the trouble of machining and installing a wheel that is too thin. Doing this would lead to slippage. Let me know if you have any further questions. Thanks,
