Need Help Trans Hard To Shift Into All Gears
Hey guys I just installed a Ram Powergrip HD about a week ago along with a new style slave cylinder. Anyway I was out last night and raced one car all night otherwise I was just cruising around. Well after that race about 30 minutes later 1st and 2nd gear were very hard to get to engage. So I drove home and parked my car. Well I got it out today at about 7:30 p.m. and now its very hard to get into any gear escpecially reverse it grinds now.
What gives I can't figure it out by the way I do have a Pro 5.0 shifter and I took it back out just to make sure it wasn't that which was causing the hard shifts.
My friend thinks its the synchro's but why would all of them go out at the sametime especially 5th, 6th and reverse. I could maybe see 1-4 but not all the gears. I need help with this bad as race season starts in 3 weeks for me.
Thanks for all the help anyone can give
The drill mod will only address quick shifts. Your prob. seems to still be a poorly releasing clutch. With all gears affected at once, I think it rules out the synchros. It can affect the synchros if you let it go for long, though.I suggest going back and working on the bleed.
what else could I do to bleed it right now it shoots fluid out of it when you crack it open but still doesn't go into gear for **** and reverse is damn near impossible without 2 hands. I need to figure this out I never had this problem til after the clutch install is there something I'm missing and its a Ram Powergrip HD
Thanks for anymore help
