did i install defective master?
My clutch pedal went soft three weeks ago and wouldnt go into any gears...so i replaced the master bleed it and started driving. was good at first but now it is doing the exact same thing. drivin down the road and i have to pull over and pump the pedal for 10 mins to get it back in gear. when it is doing this the only gears im able to get it into are 1st 3rd and 5th. I took it to a shop and had them bleed the system thinkin maybe it needed more bleeding. didnt work and now hes suggesting changing the master again. this is starting to get exspensive and frustarting...any ideas?
