Spec Stage 3 Clutch Prob
I just got done doing heads, cam, clutch and flywheel, 160 therm, slp long tubs, and a 80mm throtle. I got the car dyno tunned today and I got 408 which i was hoping for more but thats pretty good. I have have a a loud tick commin from the heads which i think is eather the rods,rockers, or lifters. I have new rods and lifters but kept the stock rockers. Any one have the same problem with this issue becasue this tick is driving me nuts.
As for the clutch, I installed it right and now i can not powershift at all. This really pisses me off becasue this is my strong point at the track. If i hold the gas all the way and shift sometimes i get second but never third unless i let off the pedal. I never had this prob with the stock clutch. I could hit second and third all day. Does anyone have any ideas on this issue as well???
Thanks
Thanks
Originally Posted by CamaroSS22
on the spec 3+ ive heard you cant powershift a spec without it.
Did you break in the clutch???
I just had my SPEC clutch 3 installed on my ride. Did you break it in before the dyno tune? My tuner recommended I break in the clutch before I dyno tune my ride. Got some heads and a cam.
I e-mailed SPEC too and they also recommended that I break her in before the dyno tune.
I also repalced the slave and hydraulic clutch reservoir.
