Hard to get into gear on nitrous?
Recently my tranny has been acting a little definately then usual. I'll try to explain. When just driving normal it shifts through all gears perfect, with no hestiation or strange feelings. Only when I try to downshift into 2nd it's extremely hard to get in gear but if you just act like your going to first and barely push toward it and then move into 2nd it's perfect goes in with no weird sounds or anything.
Also, when I seem to use nitrous on the car when I shift it seems like I'm hitting a wall like nothing is there in 2nd gear and sometimes 4th. Like it's not there for a split 2nd then it goes right in with no grinds or sounds.
What could this be? I was thinking of a few options maybe bleeding clutch and putting a poly trans mount? Could these be it? I don't want to waste money for fixes that don't work.
Car also has RAM adjustable master and slave cylinder with a KY Clutch ( local clutch maker)
