97 camaro clutch bleed closed system
take the slave cylinder and bring it above the master, i cant remember wether to point up or down i believe down and slowly push in on the rod with the cap off. u should see the air bubbles do this till there gone hope this helps
the plastic retainer was not broken from pumping the system. Meanning air was still in the syatem.So I backed off the slave and then pumped the system. Heard the strap brake and bolted down the slave back down. Works a whole lot better. The rest should work it self out with use. Thanks for the help. Bigmel
